ok when i play my music my voltage never drops below 12 volts (have the big 3 done, HO alternator and 2 batteries (kinetik 2000 and 2400).
just got new subs in (fi bl) and played it lower than i usually do with my alpine type x's.
so basically with the type x's the amp only shut off sometimes (when i play the volume on 25) but voltage would never be below 12 once again. i played the volume on 23 with the bl's and it did it today.
when this happens 2 things either happen the amp shuts off and i restart my head unit and it plays like normal or the fuses blow and i have to replace them.
i have the same amps on the subs (alpine pdx 1.1000) and only one run of 0 gauge going to the back and through a distro block (4 ways 1 amp for each sub, 1 amp for highs, and a battery)
what do you think is the cause of the amp shutting off?
Fried outputs on your amp or too little fuzes.
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
Make sure the ohm load you have the subs wired it can be handled by the amplifier (like Cr@sh said pretty much). Also check all of your connections and make sure they are snug fit. Also check out the fuse rating on the amp, and make sure you are using the correct fuse size for the amp (like Bigballa39213 said). That's the easiest stuff that you can do to check, if all of those are good, might wanna take the amp apart and look at the guts and see if there is anything visibly wrong with it.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
both on 2 ohm and if its fried outputs then is it fixable?
when i had the bl's installed they said the connector output on the amp was bad and just changed it
Edited by LiL PiNoY
What deck? At 3/4 gain it takes.. hmmm... about 0.5v maybe to drive a PDX into clipping. My friend's ones are set to minimum gain with a 6v headunit and it clips at about 2/3 volume on the deck.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1037 Guests (See full list)
