dmanson Posted December 2, 2009 Report Posted December 2, 2009 Well I currently have two runs of 1/0 ...... one for positive and the other one negative ........ my voltage is holding up very good with my DC 260 alt (doesn't drop below 15.1). I'm thinking about doing another run of 1/0 for positive which will make it 2 runs of positive and 1 negative. i want to spend as less as possibe and a run of 1/0 from my underhood battery to back batteries is only 15 ft which i'm sure i can purchase for around $35 on ebay. i also though of when i do another run of positive to just do a short run of negative from my back batteries through my floor and ground to my rear frame. what do you guys think????? 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
kl0wn Posted December 2, 2009 Report Posted December 2, 2009 Well I currently have two runs of 1/0 ...... one for positive and the other one negative ........ my voltage is holding up very good with my DC 260 alt (doesn't drop below 15.1). I'm thinking about doing another run of 1/0 for positive which will make it 2 runs of positive and 1 negative. i want to spend as less as possibe and a run of 1/0 from my underhood battery to back batteries is only 15 ft which i'm sure i can purchase for around $35 on ebay. i also though of when i do another run of positive to just do a short run of negative from my back batteries through my floor and ground to my rear frame. what do you guys think????? Just wondering..but..if your voltage doesn't drop below 15.1, why worry about doing another run? 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
dmanson Posted December 2, 2009 Author Report Posted December 2, 2009 Just wondering..but..if your voltage doesn't drop below 15.1, why worry about doing another run? in the future i plan on either getting a bigger amp or going with two DC3000 amps 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
uhoh_45 Posted December 2, 2009 Report Posted December 2, 2009 yeah as of now just get one run of + run it and get couple feet extra and add them to the neg and ground that to the rear to help out grounding a bit R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
dsmdan Posted December 10, 2009 Report Posted December 10, 2009 I ran 2 runs of 1/0 for power and ground in my truck. There's about 65ft worth of 1/0. -Dan Kasun 05' Dodge Ram 1500 QCSB Hemi Blow-thru build in progress. 2 RD HW18's, RD D9, 5 Deka 9a31's, 6th order blow-thru box, Eclipse 7200mkii HU, 140' Knu Kollossus wire. DC Power 270xp Alt, Etc.
dmanson Posted December 11, 2009 Author Report Posted December 11, 2009 yeh that's my future plan. then i'll do a ground to the back frame to help out the one negative run of 1/0 from front to rear. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
