New, help me with my first setup please.
Ok well it is way better than running paper thin wires to it they,ll melt depending on what you are running if you know what i mean thin wires=Hot melted or your car an actual commercial heating oven i mean you choose i was just saying the thicker the better more power flow. Thats all no biggy
Edited by Rydaz1Bass
VehicleCurrentlyOwned:2000Malibu
\/MySystem\/
Ken-Wood HeadUnit
Cars interior panels Custom blue Done by ME
Pheonix Power block running both amps
Stinger pro series four gauge wire flex material
RimsBrand:Polo
Interior lighting Blue neon bars under and around dash
Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED)
http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg
http://www.dcsoundlab.com/images/header.jpg
I'd suggest you do a ton of reading on the forum + read as much as u can from bcae1.com... It's best to get sum basic knowledge under your belt before you start throwing money around. Between the 2 sources there is plenty of information that can get u started on learning all of the basics.
1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN.
Pioneer AVIC-N2
(12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each
Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s
26ft3 @ 33hz w/ a ton of port area
156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
:unsure: are you telling this guy to run 2 or 4 gauge to his subs?
From his amp to his subs when he gets it all in gear.
\/MySystem\/
Ken-Wood HeadUnit
RimsBrand:Polo
He is referring to the wires that are run for your speakers power for you amp...etc. Wire is measured in gauges for example 0 gauge is about .5 inches thick and the higher the number of gauge the smaller the wire is...example 12 gauge is a hell of a lot smaller the 0 gauge. A good website that I have always gone to is www.crutchfield.com there is an option under the car audio section called outfit my car. It will tell you exactly how certain radios will fit in the dash and other stuff like that. In most cases they wil include a perfect trim piece and other useful installation accessories. By no means am I saying buy everything from them but it is a good baseline to judge other options off of.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
yeah www.cruchfield.com is a pretty good online place to buy stuff off of.
\/MySystem\/
Ken-Wood HeadUnit
RimsBrand:Polo
  • Who's Online   1 Member, 0 Anonymous, 1212 Guests (See full list)
