dmanson Posted December 9, 2009 Report Share Posted December 9, 2009 if his amp is drawing 200 amps then one run 1/0 is sufficient enough that's true but if he upgrades to a bigger amp or more amps later he'll be good to go. but as for now with only drawing 200 amps ....... yes one run of 1/0 will do. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
Slappin F150 Posted December 9, 2009 Report Share Posted December 9, 2009 No need for all that wiring on a dat2500. A single run of 1/0 would do just fine. And as for one of your questions. Amp negative to battery negative is best. Quote Team DC! 2005 F150 | Pioneer | Infinity Kappa 6x8's | MTX 3404 4 Channel | Q Logic Kicks | KNU | DC | AQ | 1998 Taurus | Alpine | Punch 5x7's | Rockford Fosgate | MTX | KNU | Link to comment Share on other sites More sharing options...
zfrerichs Posted December 9, 2009 Report Share Posted December 9, 2009 I don't really see a point in doing more than 1 3/0 run or even 1 2/0 run if his amp is drawing 200 amps then one run 1/0 is sufficient enough No need for all that wiring on a dat2500. A single run of 1/0 would do just fine. And as for one of your questions. Amp negative to battery negative is best. over kill ftw! never hurt anything by adding more wire, as long as its done right. if it were me id lose the fuses but thats me. i would atleast lose one of the fuses on each strand no need for both they add resistance as well Quote Roseville, CA Link to comment Share on other sites More sharing options...
