im attempting to build a box for 1 18" fi btl to go in a 1993 ford f150 super cab i think it is(2 doors with the bench seat thing in the back) i have no idea what to do for box designs but i want it tuned about 34 35 hertz and i need like a blue print type thing and how much mdf im ganna need, i want the speaker in the middle of the seats and not sure about the port. thats what i had in mind tho if someone can think of something beter for the space i have that hits low plz lemme kno
Edited by teddy9090
need measurements of the space u have to work with and $$$$$$$$$ it takes time to design
Edited by t-money
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
measurements are roughly 4 ft wide by 3ft tall by 1.5 ft deep, i also need something in the way of an amp rack for about 3 amps or more but will only b holding one for now till i get some fiberglass work done for mids and highs
Edited by teddy9090
You're gonna need exact dimensions, what kind of power you're running, what you're looking for in a setup, etc if you want a proper design done.
Pioneer AVIC-N2
thats what im trying to get im ganna run about 3k rms to 1 18" fi btl i want the box tuned around 35htz i need someone that will design a box that is slot vented that will fit in that area and have enough air space and port volume for the fi btl or if someone can suggest something that will hit as hard maybe 2 15" that will b about the same as the btl or something like that
ok so im lookin thru ebay at amps and i find this http://cgi.ebay.com/HIFONICS-BXI2607D-MONO...=item518b4bf967 says its mono block 1channel yet there are 2 sets of speaker outputs how does that work is that for dual voice coil subs or what??
  • Who's Online   0 Members, 0 Anonymous, 581 Guests (See full list)
