velcroslap Posted December 9, 2009 Report Posted December 9, 2009 (edited) Just got mine today and was wondering how much power I should feed into the crossovers. I'm running one amp to feed both the woofers and the tweeters. The woofers are 100rms and the tweeters are 75rms. Now my question is do I feed 100 watts or 175? I assume ohms stay at 4 when using one amp. Edited December 9, 2009 by velcroslap Quote * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic
iTech Posted December 9, 2009 Report Posted December 9, 2009 Are you tryin to feed power to the subs through the T1000BD? Or do you have a 2-Channel or a 4-Channel Quote My Official Feedback Thread PSN - tech2332 Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
velcroslap Posted December 9, 2009 Author Report Posted December 9, 2009 Are you tryin to feed power to the subs through the T1000BD? Or do you have a 2-Channel or a 4-Channel I'm trying to see how much power I need to send to the new T1652-S set from a 2-channel(not in my sig) Quote * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic
iTech Posted December 9, 2009 Report Posted December 9, 2009 I'm trying to see how much power I need to send to the new T1652-S set from a 2-channel(not in my sig) Oh okay, well what 2 channel do you have? You can't really control how much power you feed it, except for lowering the gain if the amp is too powerful. How much is your 2 chan. amp rated at 4 ohms? Quote My Official Feedback Thread PSN - tech2332 Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
velcroslap Posted December 9, 2009 Author Report Posted December 9, 2009 Oh okay, well what 2 channel do you have? You can't really control how much power you feed it, except for lowering the gain if the amp is too powerful. How much is your 2 chan. amp rated at 4 ohms? I dont have the 2-channel yet. I'm asking so I can find out what power range the amp needs to be. Quote * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic
iTech Posted December 9, 2009 Report Posted December 9, 2009 (edited) I dont have the 2-channel yet. I'm asking so I can find out what power range the amp needs to be. Ahh my bad, I understand now. I believe you would need to get a 2-Channel amp that outputs 100 Watts RMS X 2 Channels - (1 for each crossover) @ 4 Ohms. Someone correct me if I'm wrong. Edit: Here's a Rockford Punch that would suit those, Just to give you an idea of the specs. Edited December 9, 2009 by tech2332 Quote My Official Feedback Thread PSN - tech2332 Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
velcroslap Posted December 9, 2009 Author Report Posted December 9, 2009 Ahh my bad, I understand now. I believe you would need to get a 2-Channel amp that outputs 100 Watts RMS X 2 Channels - (1 for each crossover) @ 4 Ohms. Someone correct me if I'm wrong.Edit: Here's a Rockford Punch that would suit those, Just to give you an idea of the specs. see thats what I thought at first. Then when looking at the crossover it has inputs for the tweeter and woofer, which would mean 100 watts to the woofer and a seperate 75 watts to the tweeter if running two amps. Since I'm only running one amp, I was wondering how a 100 watt channel @ 4ohms can feed a 100 watt woofer and 75 watt tweeter. Quote * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic
iTech Posted December 9, 2009 Report Posted December 9, 2009 (edited) The main deciding factor is actually the mid range driver since the coil on the tweeter is so small. It has a small effect on the overall impedance. Since they aren't playing the same frequencies, their impedances don't add together. So I think you'll be fine with what I said. Edit: Spelling Edited December 9, 2009 by tech2332 Quote My Official Feedback Thread PSN - tech2332 Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
MrSkippyJ Posted December 9, 2009 Report Posted December 9, 2009 see thats what I thought at first. Then when looking at the crossover it has inputs for the tweeter and woofer, which would mean 100 watts to the woofer and a seperate 75 watts to the tweeter if running two amps. Since I'm only running one amp, I was wondering how a 100 watt channel @ 4ohms can feed a 100 watt woofer and 75 watt tweeter. Give em 150 watts if you are using a 2 channel amp, you will be fine. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
velcroslap Posted December 9, 2009 Author Report Posted December 9, 2009 The main deciding factor is actually the mid range driver since the coil on the tweeter is so small. It has a small effect on the overall impedance. Since they aren't playing the same frequencies, their impedances don't add together. So I think you'll be fine with what I said.Edit: Spelling thank you Quote * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic
