uhoh_45 Posted December 11, 2009 Report Posted December 11, 2009 just a quick question here but could i use my antenna output to turn on my tr7? or should i just stick with the remote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Mendozauly Posted December 11, 2009 Report Posted December 11, 2009 Dont use the ant because the tr7 will turn off if you change to the CD player or your ipod. What are you using the TR 7 for? I only use them at the shop to do the bypass for Alpine T.V's. Alpine D900 head unit 7" flip out t.v Kicker 6 1/2 components (front,rear)KS 6502 MB quart 3 1/2" in front A/C vent's (center channel) DC Audio LVL 5 18" (pair) Custom ported box Sundown 4500 at .5 Sundown 100.4 XS 3100 up front and a pair of XS 6500 in the rear. 1 17" Eiger Vision T.V 2 7" Eiger Vision T.V in Second row. Dynomat Top to Bottom (foam in all halo beam's) DC Eng Alt 260SP and a 400SP dual set up. big 3 Sitting on 24" If your neighbor don't complain it's not Loud! So you best go fix your shit !!!!!!!!!!!!!!
uhoh_45 Posted December 11, 2009 Author Report Posted December 11, 2009 ah i figured as much just wanted to see before hand and its to bypass the e-break on my IVA-D105 R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Mendozauly Posted December 11, 2009 Report Posted December 11, 2009 Hey but for alpine it's not gust your e brake it's your e-brake and foot brake. Yellow and black and ? Alpine D900 head unit 7" flip out t.v Kicker 6 1/2 components (front,rear)KS 6502 MB quart 3 1/2" in front A/C vent's (center channel) DC Audio LVL 5 18" (pair) Custom ported box Sundown 4500 at .5 Sundown 100.4 XS 3100 up front and a pair of XS 6500 in the rear. 1 17" Eiger Vision T.V 2 7" Eiger Vision T.V in Second row. Dynomat Top to Bottom (foam in all halo beam's) DC Eng Alt 260SP and a 400SP dual set up. big 3 Sitting on 24" If your neighbor don't complain it's not Loud! So you best go fix your shit !!!!!!!!!!!!!!
