even if it got built in the trunk it might be hard droppin the sub in
Exactly what i was meaning if you had it all built up and nice looking you couldnt push the sub back in the box so it is better for you to just minus off some inches but once you got the sub in the box then put it in the trunk dont forget your wire turminals id use pretty decent size bolts for terminals just drill holes and put them in the hole and tighten up on the inside if you know what i mean its very hard to explain imo
VehicleCurrentlyOwned:2000Malibu
\/MySystem\/
Ken-Wood HeadUnit
Cars interior panels Custom blue Done by ME
Pheonix Power block running both amps
Stinger pro series four gauge wire flex material
RimsBrand:Polo
Interior lighting Blue neon bars under and around dash
Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED)
http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg
http://www.dcsoundlab.com/images/header.jpg
ok thanks everyone for the inputs, really appreciate it.
2006 Mazda 3 sedan
Fi 18 BTL
AQ2200D
7 cubes 32hz slot ported box
JL mids/highs
JL G-4500
Alpine CDA-105
Big 3 in 1/0
Soundstream 55ah front
Amptech 100ah rear
go get yourself some cardboard and make a box thats 18hx34wx24d then try to get it into your car if you cant you know its to big ;)
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
hey guys, little update, went down to get a qoute on a box since the cardboard one I made cudnt even fit thru the door haha, so they guys said the box doesnt have to be that big, and it has to be tuned to around 40hz, I was like umm ok,, so they will make the box for around $500au,,, what u guys think?
2006 Mazda 3 sedan
Fi 18 BTL
AQ2200D
JL mids/highs
JL G-4500
Alpine CDA-105
Big 3 in 1/0
Amptech 100ah rear
40hz my ass. you can tune lowwwwww on a BTL with ease. also if youre going ported make sure the trunk has some air flow, if its up against the wall on every side its not gonna be very good.
IMO even if you some how manage to get the 18 and the box in there its going to be suffocated and youll never really see the full potential of it. Plus the fact that your box will probably end up being too small for the sub just to make it fit into the trunk, its just going to be too much work for too little result.
A 15 would work much better.
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
yep yep, alright I see what u guys are saying, so I really should tell the guys to make the box as big as possible that can fit in the trunk, plus the port will be facing inside the car, so plenty of air flow will get in.
2006 Mazda 3 sedan
Fi 18 BTL
AQ2200D
JL mids/highs
JL G-4500
Alpine CDA-105
Big 3 in 1/0
Amptech 100ah rear
