i was wondering if there is something that you can download online to measure your db level?
New to the car audio world, and who ever said this is an addicting hobby they were right!!
accurately no...
but i found a program
called true RTA
its fun to watch it move. but whenever the bass hit the DB level went down to like 80....
it might work better on ur comp tho
idk
if you want true DB levels you need a term lab
1 octave incriments is free
http://www.trueaudio.com/
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
To be accurate you would need a Term Lab Pressure sensor along with the sofware, which would be around 500 bucks, but if you just want to compare against your freinds with unofficial scores and your not running crazy amounts of power you could run with the Walmart meter for 25bucks.
¿ǝɯɐƃ ǝɥʇ
thanks man are term labs expensive and does the program of the internet have instructions how to hook up to your comp??? thanks for the help
it just uses whatever mic is with your computer
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
so i juss play the music
yup
just play it and the bars will move
it has a peak hold too
but really do not expect it to work well
my DB level dropped extremely when the bass started
i think it choked out my mic
Edited by IH8PunkRok
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Yeah it clips your mic to bits. I had a play with it (got the high resolution version) with a Behringer ECM RTA mic and I think it was good for about 125dB.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
