tip n tell Posted December 17, 2009 Report Posted December 17, 2009 Help Will 3 deka A31 power 2 goliath xxv with a 170 amp and 240 amp I hope it can. btw not much room left in my car. :censored: No warranty 95 civic air-ride RE-5 slam specialties 4-18's Dc xlm2's tuned 35hz 2-1100.1's @ .35 each 2-SD 250.2 nano amps 3-deka 9a31 1-deka 35ah 2-250 amp alts/ Adjustable regulator 159 sealed @ dash 51hz
sully Posted December 18, 2009 Report Posted December 18, 2009 you have enough alternator so it should be fine. That is 3 A31's dedicated for stereo plus a starting battery under the hood right? 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
tip n tell Posted December 18, 2009 Author Report Posted December 18, 2009 you have enough alternator so it should be fine. That is 3 A31's dedicated for stereo plus a starting battery under the hood right? Yes that is the A31's looking for starting battery. No warranty 95 civic air-ride RE-5 slam specialties 4-18's Dc xlm2's tuned 35hz 2-1100.1's @ .35 each 2-SD 250.2 nano amps 3-deka 9a31 1-deka 35ah 2-250 amp alts/ Adjustable regulator 159 sealed @ dash 51hz
Marlo Stanfield Posted December 18, 2009 Report Posted December 18, 2009 That's a lot of power you'll be running, especially for daily... Granted you should be ok with only 3 batts, I'd suggest adding at least 1 more Deka plus a solid under hood batt. Then have dual 1/0 power + ground runs from each amp obviously. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
tip n tell Posted December 18, 2009 Author Report Posted December 18, 2009 That's a lot of power you'll be running, especially for daily... Granted you should be ok with only 3 batts, I'd suggest adding at least 1 more Deka plus a solid under hood batt. Then have dual 1/0 power + ground runs from each amp obviously. One more deka out of room 3 tops. Plus the weight poor civic. No warranty 95 civic air-ride RE-5 slam specialties 4-18's Dc xlm2's tuned 35hz 2-1100.1's @ .35 each 2-SD 250.2 nano amps 3-deka 9a31 1-deka 35ah 2-250 amp alts/ Adjustable regulator 159 sealed @ dash 51hz
