CaptainzPlanetz Posted December 19, 2009 Report Posted December 19, 2009 Well after installing my mids and highs amp a few weeks ago, I have noticed I have some Engine noise in the speakers. So with that being said I was gonna ground my RCA's to the back of the deck, but didnt really know how to go about doing it, as my deck(Clarion Maxx675VD) has a harness that comes out of it about 5 inches that has all the different connections, including front/rear/sub female RCA connections. So my Question is how would I go about grounding these. And if I am unable to ground them would this Ground Loop Isolator be a good choice to get rid of the noise and if not which one would you reccomend? http://www.darvex.com/SGN20/Stinger+Ground...p+Isolator.html ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
uhoh_45 Posted December 19, 2009 Report Posted December 19, 2009 is your power wire ran next to rcas? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
CaptainzPlanetz Posted December 19, 2009 Author Report Posted December 19, 2009 is your power wire ran next to rcas? Nope other side of the car, even in the trunk they are nowhere near eachother. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
CaptainzPlanetz Posted December 20, 2009 Author Report Posted December 20, 2009 Here is a Picture from the Manual to give you an idea of how it is. It doesnt have the standard RCA femaile connectors mounted on the back of the unit, my guess is they went the harness route since there are so many peripherals that can be connected. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
creyc Posted December 20, 2009 Report Posted December 20, 2009 How are you grounding the head deck? Through the factory wiring harness? (black wire) 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck
uhoh_45 Posted December 20, 2009 Report Posted December 20, 2009 do this but keep the middle of the wire with its jacket on R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
LunatikGixxer Posted December 20, 2009 Report Posted December 20, 2009 usually when u can hear alt noises through ur speakers its most likely bad grounds. Amp grounds, HU grounds, etc.. 2002 Dodge durango 4.7L Autopage 2 way remote start alarm system 2 AQ 15 Aluminum coils. 1 AQ2200D (soon to be 2). 8.5 cubes tuned to 38hz. Yellow top under hood. Kinetik 1800 in rear. Big 3. (H/O Alt Soon to come) Kicker ZX200.4 Kicker 6.5 doors (blown) RF 6.5 comp set (soon to come) 1 run of Stinger 1/0 guage (soon to be 3) All of the above is all gone Currently own a 2000 Pontiac Trans Am WS6 No audio components.
treossi Posted December 20, 2009 Report Posted December 20, 2009 my kenwood was having a problem with that in my other car.. so i ran a ground directly to the battery... i think the ground wire on the factory harness wasn't good enough... it fixed the problem Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
