1 ohm vs 2, 4, 6 or 8 ohm
FreekDesignz
the lower the number.... the lower resistance the subwoofer coil has
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
well a 1 ohm load will make your amp produce more power than an 8 ohm load
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
you have to think about ohm loads when you buy subs... so you can match them with your amp.. so if you wanted to buy one sub.... and you have an amp that's only 2 ohm stable... you should get a dual 4 and wire it in parallel to 2 ohms... i know it sounds complicated.. im not the best at explaining things.... it's basicly resistance of the coil that's inside the subwoofer
from what I've been told, 1000 Real RMS@8 ohms, is the same as a Real 1000@1 ohm. ohm load just gives diff. wiring options
If Morgan Freeman narrated a story on how great AIDS is, I would be captivated and tempted to contract it myself. His voice just fills my soul with warm fuzzies and puppy tears.
He has NO idea and may have a touch of autism to be honest.
Is this guy real or is he joking? i actually mistook him for a lesbian in that demo video
Wanted to mess around with a box for the garage. Was thinking 4 6x9 in 4 cube at like 30 hz...
These are the things that make me lol
ooooo i see, ihav 3, 4 ohm kicker 12" L5 (square) subs @ 600 rms watts each do u hav ideas on tha best amp or amps 4 them
you should check out www.the12volt.com it has calculators and can show you how to wire all different kings of subwoofers
well i would get an amp that puts about 2000watts rms @1ohm your subs will wire to 1.34ohms when in parallel
or you can get 3 amps that are all 600watts @4ohms
97 Honda Civic Sedan
Rear disc brake conversion
2" drop
17's
lots of exterior mods
SYSTEM
SoundStream VIR-5850 Dvd player
RE 6x9's and 6.5's
Soundstream DTR4.500
Soundstream DTR1.2200
8" RE-x in a t-line
Kinetik 1800
Plans
4-SA-8's
Another Kinetik
High output alt
My Cardomain
  • Who's Online   0 Members, 0 Anonymous, 507 Guests (See full list)
