coil burning??
LoudBimmer
The SAE-1200D is a very under-rated amp... if your sine wave for gain setting is recorded at a lower level than the music you listen to then your actual power delivery will be higher.
i think he used -3 or -5db
which is standard and really only djbilly and sine waves are louder than that
(it is a niice amp)
u have me perplexed with ur issue, it should be solved by now, ugh
either way u have a small box so it should be fine with an extra 100w, lol
maybe uve already dont alot of damage to the coil already... what does the color of the coil look like to you when u took it out to wire it correctly
idk, i will take it out today again to check all the wiring and will snap a picture of it.
i thought the amp will put out different voltage on different voltage
12.8V actual rms in manual
14.4 higher then normal
i will check coils today with DMM
its not scientific fact but a general rule of thumb is that if u drop below 12v bumpin on music while driving say 30mph(alt engaged) then u need to upgrade ur electrical
the sundown should be fine below 12.8v, but it will pull more amperage as the volts go down, which creates heat... our enemy, lol
so what should i do? lower it to 20V-22V?
u should locate an oscope
ask colleges near you with majors in something electrically related
autozone
a diesel truck shop
that would help figure out the best headunit settings
then u can set ur gain knowing its clean
after that if u have stink, get a different sub, lol
well, good news is both coil are good ( 2 ohms), i changed output voltage to 20V, and car voltage drops to 11.8-12.0V.
quick question.
by electrical upgrade you mean new alt or add another battery in the back?
big 3 and a bigger alt. DC Power ftw
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
