coil burning??
LoudBimmer
you can. should you? NO
you should probably go to your local shop and tell them to look over everything you installed so you don't burn up your car and all your gear
laught it off, so can i run it with no fuse for about a week or 2?
sorry if i was rude, but u know... kinda of a noob mistake
if ur power wire gets a cut and short on the metal, ur battery will have no protection... thats the sole purpose of the inline fuse
trim the wire down til the 1/0 fits and when u get 1/0 fuse holder cut the trimmed part off so u can use all the 1/0
problems solved!
ok, so, before i will rewire sub,i'm gonna ask a question
+ from one coil i will connect with + from other side, will do same thing with -, and i will connect them together( + with+ and - with -) and run them. 2 wire's + and- to amp + and -. right?
this is simple...
connect both positive sub terminals into the positives on the amp
same with negatives
thats how u wire a dual 2 ohm to 1ohm final
Didnt read page 2 and 3..
clipping should of been the answer for the 2nd post lol..
If its clipping, then yes ur coils are burning, and thats probably whut u smell, ive smelt it before too when clipping.
2002 Dodge durango 4.7L
Autopage 2 way remote start alarm system
2 AQ 15 Aluminum coils.
1 AQ2200D (soon to be 2).
8.5 cubes tuned to 38hz.
Yellow top under hood.
Kinetik 1800 in rear.
Big 3.
(H/O Alt Soon to come)
Kicker ZX200.4
Kicker 6.5 doors (blown)
RF 6.5 comp set (soon to come)
1 run of Stinger 1/0 guage (soon to be 3)
All of the above is all gone
Currently own a 2000 Pontiac Trans Am WS6
No audio components.
i thought you only have to hook up 1 coil. cause right now i just have 1 side hooked up.
I'm sorry but epic fail.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
then dont post
u just made a dumb arshe comment because we already figured out he had one coil hooked up
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
