the one thing mike didnt discuss i the vid is what size wire to use. you would think the larger the better, but if you put 1/0 wire on the + of your alt and its not made for it the bolt can then act as a resistor and build up wayy to much heat and possibly melt components of the alt. 4 gauge that short can carry more than enough current for your application
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
well for a single cab just do a larger alt and try to fit the biggest,best batt in the tray..when you're driving and your alt provide enough amps you don't need a huge bank of batts..
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
If you have a bench
Hook up the Big 3 and a 200amp alt and you should be ok.
If you have buckets w/ center console
Hook up Big 3 and run a secondary battery in the center console. run batteries underneath and no problems should come up.
If still having voltage issues.
add battery to having a bench
---------------or-----------------
add alternator to buckets setup
I wouldn't run a cap because they are more of a headache then the money they are worth.
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
If you have a bench
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
Dang bein apart of this forum even tho im not on it much is pimp . Preciate all the advice 4real !! So im gone do a big 3 upgrade hook everything up and c wut happens and go from there ! I didnt running a true 1000 rms would b such a big deal lol ! But i do have one of the best amps out there JL audio 1000/1 v2 !!!
  • Who's Online   0 Members, 0 Anonymous, 2441 Guests (See full list)
