TeejayBee Posted December 23, 2009 Author Report Share Posted December 23, 2009 nvm i figured it out lmfao xD Quote Link to comment Share on other sites More sharing options...
Boon Posted December 23, 2009 Report Share Posted December 23, 2009 That diagram only works if you're planning to run active. Or seperate passive crossovers... Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
tacomabanga1986 Posted December 23, 2009 Report Share Posted December 23, 2009 ya, dnt just str8 wire ur tweets to a fullrange amp it will blow em in a heart beat if i was u ied either run active or get a cheap 3 way xover n run ur amp active or just take the mids, run em on channel 1 n 2 or 3 n 4 doesnt really matter w/o xovers and run tweets on the opposite channels of the mids n run xovers to em just take the comp sets xovers n just take some speaker wire n run it to the input on the xover n then run wire from the tweet output to the tweets and just leave the mids out of the xover network just make sure there xovered pritty good at alteast 80htz or higher on the headunit or amp n u should be good and with the extra tweets, they should come with there own xovers so just wire them up normal, speaker wire from same channels as other tweets pos n neg n wire into second tweets xover input n then tweet output to tweet n u should have a 2ohm load for tweets maby i unno n 4ohm for mids but if i was u ied run 2 sets of comps vs 1 set of comps with extra tweets but to each his own, hope this helps Quote here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit Link to comment Share on other sites More sharing options...
finkster Posted December 23, 2009 Report Share Posted December 23, 2009 right on bro, make sure you wire the tweeters to the xovers... I should have shown that in my paint drawing but my skillz are limited Quote DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living Link to comment Share on other sites More sharing options...
TeejayBee Posted December 24, 2009 Author Report Share Posted December 24, 2009 So if im getting this right make sure to run everything through xovers when i get it in my house ill take pics and ask again xP Quote Link to comment Share on other sites More sharing options...
