hes not talking about the fuse on the outside of the headunit, there is a fuse on the inside of the casing IIRC, my old pioneer had TERRIBLE alt whine and i ended up putting a new headunit in and its not even existant.
Fusible link = pico-fuse or Thermal Resettable (regrettable more like!!!) device on the PCB inside the amp. It fuses the ground on your RCAs in case your amp ground ever falls out, to prevent the amp grounding through the RCAs and setting your car on fire or killing the headunit.
I did a tutorial in the head-unit forum I think?
http://www.stevemeadedesigns.com/board/ind...297&hl=fuse
There it is :)
10.x volts fo' life!
