Jwilson40 Posted December 30, 2009 Report Posted December 30, 2009 I was wondering if you guys think the AQ1200D would have any problems pushing 2 Rockford Fosgate T112D4's...or if you have any other suggestions on a better sub choice... Amp specs: Specifications Model AQ1200D Frequency Response 20Hz—250Hz Signal to Noise Ratio 100db Low Pass Crossover 24db / Oct Low Pass Crossover Range 20Hz—200Hz Subsonic Crossover Range 10Hz—50Hz Input Sensitivity 0.2V—8V Output Master / Input Slave Connection Yes Working Voltage 8V—16V Efficiency @ 4 ohm 84% Damping Factor Less than 150 Fuse Rating 40Amp X 3 (Linked 240 Amp) Output Power 14.4V @ 1% THD 510X1 @ 4 ohm, 870X1 @ 2 ohm, 1200X1 @1 ohm Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm Dash Mounted Remote Included Dimensions 12.75″(L)x9.27″(W)x2.35″(H) Speaker Specs: Size 12" Impedance 4-Ohm x 2 Power Handling 600 Watts RMS 1200 Watts Max Voice Coil Diameter 3" anodized aluminum Motor Size 124 oz. double stacked Speaker Connector Dual 8 AWG slot load Fs (Hz) 33 Re (Ohms) 6.2 Le (mH) 4.2 Qms 4.46 Qes 0.63 Qts 0.55 Vas (Liters) 34.8 Sd (cm2) 460 SPL (1w/1m) 86 dB Xmax (mm) 14 Woofer Displacement 0.08 cu. ft. (2.26 Liters) Cutout Diameter 10.8125 in. (27.46 cm) Mounting Depth 6.625 in. (16.83 cm) Shipping Weight 30.6 Lbs. (13.9 Kg.)
BeAlLsTaR13 Posted December 30, 2009 Report Posted December 30, 2009 it'll push em fine, i have a 1200d pushing my 2 12" cvx (750 rms each) and they get pretty loud Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
kl0wn Posted December 30, 2009 Report Posted December 30, 2009 Yeah, it'll push the subs fine. Just keep the signals clean, and a steady 14.4volts 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
