8000watts Posted January 1, 2010 Report Posted January 1, 2010 i realized my valve cover gasket was leaking so i decided i was gonna fix it today. i looked around the valve cover and realized that there weren't any screws to take off to loosen up the valve cover so i was wondering if there was anyone out there who knows what it is that i have to do to change my gasket. its a 97 toyota camry with the baby engine lol (2.2L/4cyl.) the only thing that looks like it can possible help are these bolts that ARE the spark plug hole... thanks in advance! Quote
Stephen Posted January 1, 2010 Report Posted January 1, 2010 The bolts are under the spark plug boots. You need a big socket to remove the four valve cover nuts. 30mm socket Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
8000watts Posted January 1, 2010 Author Report Posted January 1, 2010 The bolts are under the spark plug boots. You need a big socket to remove the four valve cover nuts. 30mm socket just the ones i was lookin at...thank u my good friend. i'd kiss u if it wasn't gay lol. time to work Quote
