G_I_R55 Posted January 2, 2010 Report Posted January 2, 2010 just bought a Kenwood KFC-XW1222D plan on getting a 2nd ( http://www.kenwood.ca/Car_Entertainment/Su...ers/KFC-XW1222D ) manual is in downloads tab the install manual says 1.5 cu.ft just want some suggestions from more intelligent people and total noob to this fourm so... HI! In Car (02 Saturn L100) Pioneer DEH-P3100UB Kaption D1000.1( http://www.kaptionaudio.com/manuals/KaptionD-Class.pdf ) 2 stinger 1F Capacitors (don't know why...don't know why not) 1 12" Kenwood KFC-XW1222D sub Optima Red Top 34/78 (800cca) Stinger 4ga (Big 3 also done with 4ga)
tehbert0 Posted January 3, 2010 Report Posted January 3, 2010 just build it to the specs what amp you running? http://motorcitydesignsaudio.com
Marlo Stanfield Posted January 3, 2010 Report Posted January 3, 2010 What amp(s) are u running?? What kind of available space do u have?? What do u want from your setup(SPL, SQ, mix of both, etc)?? 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
berniebp87 Posted January 3, 2010 Report Posted January 3, 2010 Measure twice- cut once, be patient and don`t rush, predrill before you apply the screws, don`t use to many screws. Proud member of SMD My build log 2 DDZ9518 2 DynaBel BF 8501 2 GZ Neo 8"s 154.5@38hz with 2 DD Z9518`s 145.5@40hz with 2 DD 1508`s My youtube vids
