jlaudio16 Posted January 3, 2010 Report Posted January 3, 2010 whats a good size box for 3 10inch jbl power series (p1024)? I am looking for SPL, also i want the port to be tuned to 32hz thanks Quote
TeejayBee Posted January 3, 2010 Report Posted January 3, 2010 It isnt hard to figure out on your own. find the recommended box size for just one of your subs then times it by three then figure out the port size Quote
jlaudio16 Posted January 3, 2010 Author Report Posted January 3, 2010 o ya i thought if you wanted to go SPL, the box has to be a bit bigger than the recommended size Quote
TeejayBee Posted January 3, 2010 Report Posted January 3, 2010 well what are the specs for one of the subs the box that is Quote
jlaudio16 Posted January 3, 2010 Author Report Posted January 3, 2010 its 1.25 cubic feet with loose packed fiberfill for each sub i want to avoid using the fiberfill i don know if the fiberfill will make a difference Quote
TeejayBee Posted January 3, 2010 Report Posted January 3, 2010 dont put anything on the inside of your box it soaks in some of the sound . if im thinking fiberfill is like cotton . but okay so 1.25 ft and if you wana make it a little bigger then recommended size do like 1.75 per sub so your total is 5.25 ft now what is the box going in so i can give you dimensions Quote
jlaudio16 Posted January 3, 2010 Author Report Posted January 3, 2010 o ya, i kinda figured that fiberfill will absorb in some of the sound the box is going to go in a 1992 honda accord i got no dimensions of the trunk right now Quote
TeejayBee Posted January 3, 2010 Report Posted January 3, 2010 alright ill just put some dimensions down and then when you can see if they fit. Height - 16" Width - 35" Depth - 20" then port Height - 5" Width - 6" Depth - 11" Tunned to 32.63Hz Quote
kirill007 Posted January 3, 2010 Report Posted January 3, 2010 What amp are you going to power the woofers with? 1.75cu ft per sub is too much. Max 1.5cu ft with around 14sq inch of port per cu ft. So around 64sq inches of port area and 4.5 cu ft. Quote Thinking is the root of all problems... You ALWAYS get what you pay for.
jlaudio16 Posted January 3, 2010 Author Report Posted January 3, 2010 im going to use a clairon DPX11551 for now Quote
