Battery Terminals
yes thats what your supode to do. as long as you keep all of the wires that are there attached to the batteries + post attached you will be fine, there is actually a tutorial in the wiring section about doing the big 3 its a sticky at the top if you have questions it explains it really well
Thanks Man i really appreciate the help
no problem, good luck let us know how it goes
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
I hope im not being stupid posting this up but this is how the stinger GM sidepost adapter terminals work. You dont need the top mount terminals that you linked
You use the bolt itself to replace your stock battery terminal "bolt", this holds the stock wires on
Once its tightened then you use the small bolt that screws into the battery bolt to attach your accessory wires
In my case here, my 2 runs to the back battery, in your case the wires for your big 3.
Edit: Just saw the first terminals you linked are actually capable of being used in sidepost situations... Well you can cut your stock terminals off the wires and use that one or you can leave all of that alone and just put some ring terminals on your big 3 wires and do this way.. Either will work and both are equally safe
I Posted a pic of side post, not top post, the ones i posted was specifically for gm side post
Yah i see that now my bad.. Id rather leave the stock wires alone incase I want to sell my truck or something which is why i chose to do it this way.. To each his own
O ok yeah i can understand that, i just never thought of that, sorry for the confusion at first lol
  • Who's Online   0 Members, 0 Anonymous, 420 Guests (See full list)
