Get a tonneau cover for the bed and do a blowthrough so all you single cab guys can stop bitching lol... As far as flaring PVC the way I do it is with a metal bowl + a heat gun. It's a little much for me to type it all up right now @ 1:25am and answer questions regarding how to flare ports correctly without warping/cracking them. Drop me a PM sometime tomorrow and I'll try to help you out if you're really planning on doing it.
Pioneer AVIC-N2
id use more than 2 3" ports if your going to go that route... i was running 2 10's on 300rms in about 1.6 cubes with 2 3" external ports... granted they werent flared... but they were all sorts of port noise and whistling and shit..lol.. it was annoying
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
:D fuck it, just do a blow through
4 15" dc audio level 4 xl's in 4th order blow through
2 IA 40.1's at 2 ohms strapped with 3.9 rise...currently own 4 IA 40.1s.....
1 06zx3504 running Kicker QS 6 1/2's
1 iraggi 180 amp alt
1 optima d34 yellow top under hood
5 deka intimidators
HU - Eclipse AVX5000 W/ DCU-105
Termlabed 157db at 38hz 6000 watts
