Ok so im cruising along pounding everythings going good all of a sudden my bass kicks off... I turn my volume down for a little while and it comes back on I get out I go in my trunk, wiring is fine... sub smells fine, my gain was properly adjusted.
Any ideas what It could be? could my amp be going? maybe its overheating because my sub is too big? i have no idea... its very random and doesnt happen often, the weird part is it never happened on my old kickers... I soldered everything INSIDE my box so it cant be a lose connection inside the box i don't think.
check your grounds. and solder joints can fail BTW.
d(-__-)b
I guess I can just deal with it until I get my hifonics 1605D and knuconcepts 0/1 gw and see if it still happens, maybe it's a bad ground? and when I hit a bump it kicks off? its just weird how it'll kick off random and kick on random, I guess the ground would make sense since i've had problems with it in the past, my ground wire literally got split in two and i just taped it back together lol so it's probably a draw or something in it.
by fail do you mean fall off? if a one of my joints failed wouldnt the sub not work altogether since one of the wire wouldnt be touching? I gues I can pull my terminal out and see if it's still connected. im thinking it's a bad ground as well...my ground wire is all messed up.
theres your problem.
just because a sub is bigger doesnt mean itll overheat faster IMO. check your speaker wires also.
Edited by Kranny
mm ok I suppose I can just cut part of my power wire and use it as a ground for now.. as far as wiring i pulled my terminal on my box out and the solder joints are fine.
well i mean u answered your own question right there man, you said your ground is messed up so go fix that and i bet everything runs fine
TEAM NEMESIS
my system
1) us amps MD3D, us amps md21
2) kicker solo x 12 in 2.7ft^3 at 37hz
Meca scores
1 xxx12" 141.8db at 40hz,
1 18 rd alpha v.2 145 db at 38hz , 2 12 orion hp 144.9 at 43hz
Refs: hollatchaboy, schrummy, nitro_freak1,Brandon15zzz,Hellbound Train
replace your ground, thats not good. also what is it grounded to?
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
theres a bolt and nut on the top of my trunk that I have it grounded too I couldnt find any good spots on the rear latch of my trunk so this would be the best spot imo, I can see my amp power light (the blue light ontop of Alpine MRP amps) flicker when bass hits hard, is this a power problem indication or do all amp LED's flicker a little? also I suppose I can try a new ground spot but I have no idea where.
double check all the wiring after you replace your ground... and dont ignore it.... you dont want ur car to catch on fire...
if the LED on the amp turns off.. then it sounds like you have some serious voltage drop... do you have the big 3 done? what ga wiring you using???
My first truck... My first Real build...
*Update 8/9/10 DC Power 270xp Alt is In!!!*
1997 Toyota T-100 DC Level 5 18" in a T-line
Everybody wants their system to be....
1. Cheap
2. Reliable
3. Loud
...you can only pick two.
micahmye hertz pack
  • Who's Online   0 Members, 0 Anonymous, 366 Guests (See full list)
