ok... it is a rather easy answer... and james even gave you the formula... But you Guys dont have to be such fucking assholes about shit!
OT... 5 ports will have you just shy of 100sqin and 6 ports will have you a bit over..
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
thank you.
Edited by Percy
you know the saying, haters gonna hate..
its a forum. im sure if you used the search button and didnt turn up anything, then someone would be glad to help you. i havent done so myself.... but im damn sure that question has PROBABLY been asked before, and instead of asking a repeat topic that the older guys will mock - just browsing the forums in the search would probably let you find something..
if you cant find anything, and mention so then im sure you would have gotten a much more chill response.
-matt
Edited by glpg80
ah, you mean the peas?
It puts it into perspective. Just imagine a stadium filled to the top with peas.
Sounds like one hell of a soup lol
its a forum. im sure if you used the search button and didnt turn up anything, then someone would be glad to help you. i havent done so myself.... but im damn sure that question has PROBABLY been asked before, and instead of asking a repeat topic that the older guys will mock - just browsing the forums in the search until you find something..
if you cant find anything, and mention it, im sure you would have gotten a much more chill response. who knows.
-matt
thanks for not being a dick about it, and yes i did do a quick search about it, didnt find exactly what i was lookin for
thank you.
roughly 18.84sqin per port.... and thats if the inside diameter is exactly 6" remember when building an enclosure you have to take into account the thickness of the port "walls" when determining port displacement
3 Kinetik Hc2000's
Dual 200amp alts.
okay cool, they looked rather thin. what if it has a flare is there a special way to calculate it?
easy way of not learning it
but for a 6" port you divide that by 2 to get the radius then X that by itself then x that by 3.14
3*3*3.14 =28.26
so for one 6" port you have 28.26^2 of port
R.I.P!
(Nov-29-2009)
92 explorer
current build
