HID Legal Trouble?
read up dumbass
http://en.wikipedia.org/wiki/Headlamp
your gonna fuckin tell me wikipedia has wrong info?
i think your challeneged a little research to prove a point > you
If it's on wiki, it must be true! I'm sorry I'm going off of personal experience instead of a non scholarly source. I'm an ass...
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
read up dumbass
http://www.danielsternlighting.com/tech/bu...onversions.html
how about you read up dumbass. and its challenged.
DC.jpgDC POWER
Headlamps using projector optics cause much worse dazzle to oncoming traffic than those using reflectors for the same light output. Dazzle from the headlights of a distant oncoming vehicle is caused by the extreme contrast between the intense spot of light and the darkness of the background. Projector optics emit the light through a much smaller area than reflector optics do; therefore, for the same total light output, the light spot of a projector headlamp is much more intense and more dazzling than the larger, dimmer light spot of a reflector lamp.
It is sometimes argued that the more tightly controlled beam pattern of projector optics reduces dazzle. In fact the beam pattern is irrelevant, since unless the headlamps are misaligned, an oncoming vehicle is sufficiently far off the beam axis as to be completely outside the beam in both reflector and projector cases. The dazzle is caused by the off-axis emission arising from such factors as scattering from optical imperfections in the lamp surface, and is worse where the more concentrated output of projector optics causes that emission to be more intense.
that was pointed towards the projector lenses not HIDS
thats alot of reading. cliffs?
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
hmmm
reading > me
some very useful info there i was under the assumption that i would be legal no matter what, reading proved as long as projector lenses are installed you can run WHATEVER type of light source in the vehicle it wont do any harm.
Some "HID kit" marketeers will try to tell you that the kits are technically illegal only because the US headlamp laws are stuck in the past. That's wrong
so that means they are legal? but reading a little above proves they arent?
point made stephen my bad
basically look into your state regulations regarding HID kits for vehicles unless you have projector lenses then youll be fine running HIDs cause there wont be any excessive glare.
LOL, eric you need to come get your box homie! It's still sitting here collecting dust.. It didn't flex any... Not bad for $10 2x4 foot sheets of MDF overly braced
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
already sold the 12's lol. im pretty sure it wont fit in my trunk anyways. can only fit 16 high
