why is it better to have higher rca output voltage or buy an eq
i have heard in the past to get like headunits that have atleast 4v preouts because its better for amp signal noise or something like that i would like to know why .. i also heard some people say that getting eq would make that voltage higher but i got no clue why can someone please explain? thanks in advance
the higher the pre out voltage the lower you need to set your gains
and my line driver/Eq has adjustable preout up to 8 volts so with that i only need to turn my gain up 1/8t he the way up
but when buying EQ/ line driver make sure you get one that doesnt put out more volts then your amps imputs can handle you dont want to burn up your imput
aswell your eq will give you a cleaner signal being you have more control over what your doing
R.I.P!
(Nov-29-2009)
92 explorer
current build
how do u know what ur volt inputs are in ur amps
should say in manual
R.I.P!
(Nov-29-2009)
92 explorer
current build
should say somthing like this
(example) Input Sensitivity : 0.5 - 4.0 volts
R.I.P!
(Nov-29-2009)
92 explorer
current build
Wish I could find my EQ. It was a nice one, just never got around to installing it before I lost it lulz. Oh wellz
1992 Cadillac SeVille STS
Pioneer DEH-P7600MD
Pioneer Premier Surround
JL Audio 10W7 Ported
Kenwood KAC-7203
Kicker ZX350x4
My YouTube
Welcome to the forum! Lots of good guys here to help you out with any issues you have.
The gain knob on your amplifiers is used to set your amp's output according to how much input voltage the amp is seeing (why some amps have voltage markings on the gains, I know some Sony amps are that way at least.) The lower the voltage in, the higher the gain has to be for rated power. The higher the gain is, the harder the amp has to work. By using an input with higher voltage (like a higher-voltage pre-out head unit,) you make it easier for the amp to reach its rated output.
As for the EQ question, many EQ's have a built-in line driver that boosts the pre-out voltage. For example, this EQ ( http://www.sonicelectronix.com/item_6655_Clarion+EQS746.html ) takes a 50mv-4v preout from a head unit or other source, and converts it to a 7v output. You can also buy these line drivers separately.
EDIT: HOLY FUDGENUGGETS I got super ninja'd! :ph34r:
Too many projects, too little time...
alright thank u guys just the answers i was looking for ..now i know what too look for when i do my upgrades
thank you uhoh_45 ill keep that in mind
  • Who's Online   0 Members, 0 Anonymous, 1477 Guests (See full list)
