im trying to make basically a quiz
input and answer if correct move to the next question
my code is a follows:
#include <stdio.h>
#include <stdlib.h>
int main()
int a ;
char b ;
do {
printf("\nOpposite of 666: ");
scanf("%d" , &a);
if (a==999) {
printf("\nCorrect\n");
printf("Next Question\n");
printf("\n");
do {
printf("\nThe 13th letter of the alphabet is:");
scanf("%d" , &B);
if (b=='m') {
printf("\n");
else {
printf("\nIncorrect Learn Your Alphabet, or How to Count... ");
printf("\n");
} while(b=='a','b','c','d','e','f','g','h','i','j','k','l','m','n','o','p','q','r','s','t','u','v','w','x','y','z');
else {
printf("\nIncorrect");
printf("\n");
} while (a<1000);
now when enter m as the answer to the 13th letter of the alphabet it goes on a loop of "Incorrect Learn Your Alphabet, or How to Count... ");
i cant figure out why it does this
anyone know why?
btw if it wasnt apparent today was my first day in programming class. im just playing around with the program
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
To start with, you have 'm' in the if statement and the while statement, so even if you enter, m, it will ask the question again.
Fix that and then tell me what it does.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
do {
scanf("%d" , &B);
I think that should be:
scanf("%c", &B);
Current system:
Previous systems:
ok well with that %c change i can answer now
but after i answer the first question it gives me the second question and an automatic incorrect then brings up the question again for me to answer. then it works
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Can you cut and paste what happens when you run the program?
Been a long time since I have programmed, and I learned C++.
Current system:
Previous systems:
all i did was type in 999 and hit enter
that is what came up
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
If you type m at that point, what does it do?
Current system:
Previous systems:
this
which is basically right but with one minor error
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
It could be that you have a new line character in the buffer and it is reading it as the character the first time through. . .
What happens if you type an m at that point, and what happens if you type another character at that point?
Also note you can say if b != 'm' in that while statement instead of typing == and all of the letters of the alphabet.
Brian
Current system:
Previous systems:
