what saize fuse for a 260 amp alt by iraggi?
what size fuse do i need for a 260 amp top series alt?
the one going from the alt to the batt pos.
I have no idea...thanks. :hairtrick:
Ride Stats:
2003 Ford focus Zx3 Hatch Walled System
X1 Solo X Kicker 18" "Enclosure: 7.8 cbft, Port Firing Into a Horn, On a 90*"
X1 Rockford Fosgate 40001bd "Now a Warhorse On my dresser"
x1 0g Big 3
x1 Kinetik 2400 "x4 Kinetik 2400's"
x1 Kinetik 1800
x2 Kinetik Special Edition True Silver Battery Terminals
x20 Gold Plated 0gauge 3/8 Ring Terminals
x25 Total ft: KnuKonceptz Kable 1/0 Silver Pearl* 2500+ Strands.
x15ft KnuKonceptz 8 Gauge.
-Soon Too Be Walled
Fav Quote:
They Dont Feal Me, But They Feal Me.
i imagine you're using 1/0 wiring...
1/0 can handle 300-350 AMPS before it goes into melt down, so i'd try a fuse in that size range.
i personally use 300 amp fuses all the way through my electrical system
EDIT*****
i noticed that you're running KLMX wire, so i'd recommend 250- 300 amps for the fusing. you are on the border of needing to upgrade your wiring, because it simply can not handle that amount of current.
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
u dont if u want ur car 2 be used as a bbq pit
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
i think what you're trying to say is:
you can burn your car down if you dont use them.
if you manage to short circuit or draw more amps than your wire can handle... expect the wire to go into "melt down" as i mentioned above.
you don't have to fuse your negative wires for the big 3. just pointing that out so no one does it.
sounds dumb but people do strange things
anyway. i would do a 300 amp fuse as well for 1/0 alt to battery wire
  • Who's Online   0 Members, 0 Anonymous, 839 Guests (See full list)
