whenever i accelerate i hear a humming noise coming from my speakers inside the car. and when the car is on i hear hissing noises coming from the speakers, very annoying. my headunit and EQ are not grounded to the car's chassis. it is wired up with the cars wireharness, i used a crimp wire connector. and rca's and power wires are away from each other. amps grounds are good. i tried a ground loop isolator, that didnt work.
can it be cheap RCA's? well im not sure if they are cheap, they are rockford but they are the very old. i dont even know if they sell them no more. but the RCA's are purple.
iDA-X200/Clarion EQS746
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Alpine & Polk Speakers
Stock electrical
are they ran near the power wire, and what brand deck do you have ?
R.I.P!
(Nov-29-2009)
92 explorer
current build
no they are not. its an alpine ida-x200
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
can bad quality RCA's be the reason for whining noises?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
Ground your RCA output at the deck (more than likely this is what it is, happens all the time)
Try a different pair of RCAs
Make sure all grounds are sanded down to bare metal
2003 CHEVY TRAILBLAZER
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
2 Big Rear Batteries
A 38 HZ Box
KICK ASS!
Move any RCA cables away from the power wires. Re ground (sand down paints and make a good connection) bad quality RCA's can sometimes cause this noise if they arent insulated good. like hone audio rca cables are a no go in cars. usually not enough insulation. (rubbers etc)
im thinking it may be the RCA's. they are rockford fosgate punch, but they are really old. i hope its the RCA's.
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
Trying grounding at the Deck first.
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
A 38 HZ Box
KICK ASS!
my deck and eq are not grounded on the car's chassis, the ground wire from deck and eq is wired up with my car's ground wire harness. i used a crimped connector. you follow me? i couldnt find an area to ground both devices.
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
how exactly would i do that?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
take a piece of wire (any wire as long as its copper) and twist it around the negative shield of the rca's on the headunit itself then screw it securely to an existing screw on the outside of the headunit
  • Who's Online   0 Members, 0 Anonymous, 808 Guests (See full list)
