Strapping Hifonics 2610d
aggballeralex
I have read the manual and it states that strapping these amps are stable to 2ohm. Has anyone had any experience trying to strap them at 1ohm? I'm thinking about buying a 2nd one and I don't want to have to worry about having 2 different gain knobs that have to be set exactly the same. Anyone have any ideas? Thanks.
aggballeralex
The Build
if you strap the pair at 1 ohms each amp will be seeing .5 ohms, those are only stable down to 1 ohm, so you'd be pushing it. if it were me, I would either change the subs to get the proper load, or to run them strapped at 4 ohms.
EDIT: confused myself with ohm levels
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
Don't think it's possible with those hifonics.
They would see 0.5ohm each, and you need a strong electrical to support the current draw.
And you need to have enough box rise to compensate the low impedance.(but still doesn't garantee that you wouldn't smoke you're amp.)
I understand better now. Is it possible to run the amps seperate and only use 1 gain knob? I'm just thinking about running 2 HCCA's instead of 1. They want 2krms and strapped @ 2ohms both amps together would only be giving me around 3400ish RMS. I also know this amp does a bit under rated so I would more likely be seeing the 3k area.
I'm just wondering because if I run them seperately at 1ohm I would be able to get the RMS power I need out of them, but I dont know how to keep the gains of the amps the same.
aggballeralex
The Build
The only way to use one gain knob is to strapp them, if you run them seperatley and gain match them, you will have to use a gain knob for each amp...or another option is to get a maxx link, then you could strap them via the max link and the max link comes with a gain/bass knob
supercharged hummer h2
8 Sundown nightshade v'2 Scott Bowman built 4th order bandpass
2 precision power pcx 4125(mids & hi's)
2 Stetsom 14k2e's
alpine ina-w910
dual Mike Singer350 amp alt
8 kinetic 2400 batteries two shuriken bt 120
1 kinetic 2000 under the hood
link to build log:
My link
when u strap them at 2 ohm it will be 1 ohm
1 ohm will be 0.5
4 ohm will be 2 ohm
this is all be4 imp. rise tho
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Maxxlink may be the way to go for you if you want to keep a single bass knob.
But, you might be able to split that bass knob signal, but you might have to go all McGuyver with a soldering iron and some cable. I think those use a CAT5 wire, right?
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Looks like a CAT-5.
I just want to be able to have full 1ohm power out of both of them, and not have to worry about matching gains. If I strap them I will only get 2ohm power, correct? Or will I still get full power from each amp strapped, just a higher Ohm load?
aggballeralex
The Build
if u do a 2 ohm strap it will be 1 ohm u will get full power out of both
i have looked this up im goin 2 strap 3 (toal) 6 amp
HAHA! This whole time I didnt want to strap because I thought I would only get the 2ohm RMS from each amp if I strapped them! Thanks alot everyone. I'm def. gonna buy another and strap them. Rewiring to a different ohm load will be no problem at all. Thanks alot for clearing up all these questions!
2 HCCA's with 4K+ rms :diablo: :hairtrick:
aggballeralex
The Build
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
