I am getting ready to put some Hifonic's 6.5 speakers in the rear door and I cannot figure out how to remove the b-pillar panel. Here is a pic of the panel I want to remove.
My woman loves me, hates my habit.
If you want to remove it completely, you have to take the seatbelt off of the pillar with a T55 torx bit first. Then it should be held on with clips.
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
What the green jello driver said.
Also have to pull up the door seals.
Building The Best.....Repairing The Rest
The bitter after-taste of a poor quality job will last far longer
than the sweetness of that cheap price!
the bolt that holds that seatbelt on will be a bitch to get off if you go at it likes it some regular little bolt. i tried to take one off with a pair of vice grips one time and learned the hard way.
6 Sundown X 15s
2 Sundown NS1 V2s
C Pillar 4th order
Bagged Suburban on 24s
http://youtube.com/tlee333
you can move it around with enough room to run your wires if you just pop the panel off the clips, them seat belt bolts are from HELL :diablo: i couldnt remove the ones holding the seats down, when i replaced my carpet
  • 3 weeks later...
Would you want them easy to get out? They're like that for a reason. Make SURE if you take them off to torque them back down to the proper specs
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
