what is the best glue for a dustcap? my sx 12's dustcap it not glued down to the surface.
iDA-X200/Clarion EQS746
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Alpine & Polk Speakers
Stock electrical
5 min epoxy worked for mine
R.I.P!
(Nov-29-2009)
92 explorer
current build
really? i got some of that. a buddy of mine told be CA glue would too? thanks.
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
ca glue would be best bet but its pricey iirc
R.I.P!
(Nov-29-2009)
92 explorer
current build
but that epoxy worked fine no problems?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
i had one pop of out of 4 and that was user error (not enough epoxy)
just make sure you mix that shit up and be somewhat generous
R.I.P!
(Nov-29-2009)
92 explorer
current build
alright cool ill keep that in mind.
btw, what kinda alt you got?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
alt was stock
i used charger for 16 volt batts (more comp oriented then daily)
R.I.P!
(Nov-29-2009)
92 explorer
current build
I use this stuff called goop from home depot works great and I never had a dustcap pop off again after using it.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
really ill check out that glue. the only thing im worried is when i press down on the cap, the glue will smush out and it will look ugly. you know what i mean? got any tips? thanks.
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
