03navi Posted January 19, 2010 Report Share Posted January 19, 2010 what is that exactly ? any pics or explanation helps! Vehicle: 2003 Lincoln Navigator Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust Amplifiers:Kicker Kx2500.1, MA Audio M700XE Batteries: 1 Kinetic Hc2400 Battery Electrical: STOCK Charging System! Tsunami 40farad Capacitor, Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz) Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter Subwoofers: 2) 15 Power Acoustik Mofo Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable Video: http://www.youtube.com/2treo15 Link to comment Share on other sites More sharing options...
Decaf Posted January 19, 2010 Report Share Posted January 19, 2010 the idea is to have the port "bounce" off a surface so the wave has more time to expand so if u have a sedan and do sub back port back u are loading the port against the rear of the trunk or in home audio putting the sub facing a corner, this "loads" the corner and helps the waves expand easier some 8-10" spl setups fire aeroports against the side, again to load the port and give it something to create pressure on this can yeild better cone control among other things Link to comment Share on other sites More sharing options...
Neo_frog Posted January 19, 2010 Report Share Posted January 19, 2010 Also depending on the setup, it will essentially tune you lower using the trunk (or corner) as an expansion to the effective port volume. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
