stilltippin863 Posted January 21, 2010 Report Share Posted January 21, 2010 i am wanting to know how to find dead center of speaker....?? so i know when making rings Link to comment Share on other sites More sharing options...
Neo_frog Posted January 21, 2010 Report Share Posted January 21, 2010 Well I'm assuming you mean finding the dead center of a circle? That's easy. But I recommend finding the center of the baffle (or the equidistant centers for multiple subs), use the inner diameter of the sub to set a circle jig and cut it out with a router. But if you are limited to the outline of a sub, to find the center you need a compass with a pencil and a ruler. Pick any part of the circle and set the point of the compass on it. Draw a semi-circle that intersects two points of the circle and use the ruler to draw a line across the intersections. The you bisect that line all the way across the circle, then bisect the new line the same way. Look up on google how to bisect the lines because I really don't feel like typing it, but the final intersection will be the dead center. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
stilltippin863 Posted January 21, 2010 Author Report Share Posted January 21, 2010 Well I'm assuming you mean finding the dead center of a circle? That's easy. But I recommend finding the center of the baffle (or the equidistant centers for multiple subs), use the inner diameter of the sub to set a circle jig and cut it out with a router.But if you are limited to the outline of a sub, to find the center you need a compass with a pencil and a ruler. Pick any part of the circle and set the point of the compass on it. Draw a semi-circle that intersects two points of the circle and use the ruler to draw a line across the intersections. The you bisect that line all the way across the circle, then bisect the new line the same way. Look up on google how to bisect the lines because I really don't feel like typing it, but the final intersection will be the dead center. do you have any picture of the compass you are talking about? Link to comment Share on other sites More sharing options...
Tek Posted January 21, 2010 Report Share Posted January 21, 2010 *EDIT* sorry, repost fail. Link to comment Share on other sites More sharing options...
Tek Posted January 21, 2010 Report Share Posted January 21, 2010 the pink thing at the top Link to comment Share on other sites More sharing options...
Soloact Posted January 21, 2010 Report Share Posted January 21, 2010 If you already have the speaker,lay it face down on a piece of wood.Trace the mounting holes..grab a straight edge,and cross the lines Link to comment Share on other sites More sharing options...
stilltippin863 Posted January 21, 2010 Author Report Share Posted January 21, 2010 If you already have the speaker,lay it face down on a piece of wood.Trace the mounting holes..grab a straight edge,and cross the lines dang this is very true!!!!!! Link to comment Share on other sites More sharing options...
