I got a couple of questions for ya, Please help
I got 2 12" memphis mojos in a ported 5 cu.ft. enclosure @ 45Hz and a Hifonics XX-Colossus II along with a Kinetik HC 2400  and of course zero gage and a good glide touch alpine deck.... anyways when i play music its loud as hell i got a trunk car...94 T-bird  and i can pull off hair tricks... but when i play the extremely low bass which the box loves... the amp goes on protect.... wtf idk why the volts are the same as if it was playing a little bit higher bass.... the subs are dual 2 ohm and i got a 2 ohm amp so its wired right trust me... i do need to upgrade my alternator but why would only the extremely low bass turn it on protect right away and not the anyother bass when the volts are the same.............
my second question is if i put this same setup in a 02 yukon which is pretty much the same thing as a Tahoe would it be just as loud???? or would i have to go with a smaller SUV... any favorties?
i would have to say to double check the ohmage and make sure youre not runing a .5 ohm load
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
