wakerider1533 Posted January 24, 2010 Report Posted January 24, 2010 Got bored tonight, so decided to take apart some old computers I found in the barn, i took 2 fans from each computer and cut a piece of scrap mdf and drilled the fans with 4" deck screws, leaving about 3" between the fan and the board so there will be circulation, and it works pretty damn good and it's silent, and the best part is it was free.. Just figured I'd share It will be screwed to the bottom of back seat becuase my amp will be under the back seat '06 Mustang GT 5spd Sundown X10 Sundown SAE 1500.1 Optima Yellow Top D31 Pioneer 7'
Hellbound Train Posted January 24, 2010 Report Posted January 24, 2010 If you wanted to drop some money into some fans here are some. http://www.newegg.com/Product/Product.aspx...N82E16835706023 These move 210 CFM. If that doesnt keep your amp cool i dont know what will. Thats a great idea to use those case fans and cpu fans. Simple and effective. Make that these fans http://www.newegg.com/Product/Product.aspx...N82E16835213001 These are 240 CFM
S15_Silvia Posted January 24, 2010 Report Posted January 24, 2010 If you wanted to drop some money into some fans here are some. http://www.newegg.com/Product/Product.aspx...N82E16835706023 These move 210 CFM. If that doesnt keep your amp cool i dont know what will. Thats a great idea to use those case fans and cpu fans. Simple and effective. Move 210CFM...and will also be annoying as hell. Haha those are rated at 64dB which will come in the form of a high-pitched whine. (coming from a guy who owns a 200+ CFM 120mm fan) 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
Hellbound Train Posted January 24, 2010 Report Posted January 24, 2010 That is pretty loud depending on how hard you run them. If you could set them up to run at higher speeds when the amps get hotter or its a hotter day then that would also be a great idea.
