So the gain is set too high.
I hope you are using a true rms dmm and a 50 hz tone.
Should be set at ~36 volts. 36^2/.5=2592. Maybe a little higher depending on the actual impedance at 50 hz. When you start dropping the impedance down to where the power does not double as you half the impedance, setting gains with a dmm can be tricky. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 2876 Guests (See full list)
