you might just not have enough room for that setup.
Well I am gonna give the aeros a shot. Ill trim what I have to off them than Ill see what happens. If it sounds bad ill try the 6". And if those even suck I might try 2 6" aeros. One on either side. Ive talked to some local guys and they have said that I would even be good with 2 4" aeros with the power I have going to the subs. I wont push as much air but it will sound good in the cab of a truck. So I will do the 3 4" first.
Truck 1 96 Silverado Ext cab
4 JL w6v2 12"s
2 JL 1000/1's
2 sets of JL XR components
RF 4 Chan
Blowthrough
141.5 @ DB drag street max 3-4
148.8 outlaw.
Truck 2 silverado 2500HD Ext Cab- Building this truck now
4 RE SE 10"
JBL BPX 2200.1
Soundstream 4 chan
JL XR comp
RF 3 ways
Subs under rear bench lifted 4"
I have it figured out how to get all 3 4" aeros in there. It will fit nicely adding another baffel on the inside of the box. I cut the holes at an angle to kinda match that of the aeros and the inside baf holes are jus a little over 4". I can just put the ports together before I put th top of the box on. Problem solved. I will barely even need to trip the lip on one port. Came out perfect. Ill post up some pics.
4 JL w6v2 12"s
2 JL 1000/1's
RF 4 Chan
Blowthrough
148.8 outlaw.
4 RE SE 10"
JBL BPX 2200.1
Soundstream 4 chan
JL XR comp
RF 3 ways
Ill post up more when I get her closer. Im headed back out to cut more MDF.
4 JL w6v2 12"s
2 JL 1000/1's
RF 4 Chan
Blowthrough
148.8 outlaw.
4 RE SE 10"
JBL BPX 2200.1
Soundstream 4 chan
JL XR comp
RF 3 ways
Worst case scenario you have to go sealed....
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Sealed NEVERRRR. lol. I just came from sealed. I prefer my ported boxes.
OK here we go, Got /4 of the box built. Once the fiberglass drys I can start filling it up with sand till I get my airspace. Then back to figuring out my port length. I will assume that I will be around 5.9 after DD but We will see how close my guess was. I wouldnt mind being a little less. I would like to come in colse to 5 cubes after port displacement. Here she is, dryin in the garage makin my whole house smell like resin. The ports are just kinda sittin in there. I just wanted to make sure they would clear the floor hump and hell I just wanted to look at them. lol. Not too bad.
These are from the back side of the box. I dont want to move it around too much while its wet. I have a board over the top right now with some subs and a kinetik bat weighing it down.
I will add another baf to the front when I am getting ready to mount the subs. I think I will recess the subs too. I have some 3/8" aluminum rod that I am using for the grill guard. I will take the rod over both subs on each side and use 2 rods per side.
4 JL w6v2 12"s
2 JL 1000/1's
RF 4 Chan
Blowthrough
148.8 outlaw.
4 RE SE 10"
JBL BPX 2200.1
Soundstream 4 chan
JL XR comp
RF 3 ways
  • Who's Online   0 Members, 0 Anonymous, 627 Guests (See full list)
