Alright not that long ago i was testing my new amp, and the subs on a couple songs on the Fosgate Volume cd, And the next thing I know when i get out is a pretty loud rattling noise, so i go towards the spoiler and on the left side there is a crack that runs across the bottom of the base :shok: So now im wondering, if i line the lid and the whole trunk with Damplifier Pro will this get rid of the rattle and keep the spoiler from breaking anymore, or will i have to get it painted again and use bondo to repair it??
Edited by Toady
expanding foam helps if you fill in the little gaps but if you dont wanna "ruin" your car dont use that stuff but yes sound deadening will help reduce the vibrations and as for the spoiler some resin/fg should help stop the cracking
R.I.P!
(Nov-29-2009)
92 explorer
current build
bondo will work the best IMO
bondo cracks (from what i've seen) fiberglass and bondo ontop if need be
R.I.P!
(Nov-29-2009)
92 explorer
current build
