slim8605 Posted June 1, 2007 Report Posted June 1, 2007 Has anyone here ever played with an american bass vlf 500.1? I'm lookin for a new amp to put on a pair of BTL's and someone is sellin some on termpro for $875 but I can't find any info on them. Even on the website it doesn't give any specs on them and I just wanted to know if they actually do the 5000w like he says. 1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock
mikeneufeld Posted June 1, 2007 Report Posted June 1, 2007 vfl 500.1 is a badass amp, draws a ton of current, but very rcksolid in build and qaulity. I have a friend who ordered a atomic 5k amp, atomic and american bass same thing pretty much. 1 x 1400W @ 4 ohms (14.4V - 1% THD) 1 x 2650W @ 2 ohms (14.4V - 1% THD) 1 x 3200W @ 1 ohm (12V - 1% THD) 1 x 4700W @ 1 ohm (14.4V - 1% THD) 1 x 5600W @ 1 ohm (16V - 1% THD) 1 x 7100W @ 1 ohm (18V - 1% THD) Signal to Noise : 85dB Damping Factor : 200 Efficiency : 75% i have seen guys run these amps at 0.5 ohm daily.... def a solid performing amp with good customer service to boot www.dbdrag.ca Representin' Canada In DB DRAG
slim8605 Posted June 1, 2007 Author Report Posted June 1, 2007 Thanks a lot Mike. A couple more questions. How much do they usually go for? Specs and price on the 700.1? 1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock
mikeneufeld Posted June 1, 2007 Report Posted June 1, 2007 why not look also into the atomic 5k, cactus 5k or rd 5k, all us the same boards and can be had for a good price...... www.dbdrag.ca Representin' Canada In DB DRAG
mikeneufeld Posted June 1, 2007 Report Posted June 1, 2007 are you looking to buy direct, or used ? www.dbdrag.ca Representin' Canada In DB DRAG
mikeneufeld Posted June 1, 2007 Report Posted June 1, 2007 http://www.atomicspeakers.com/5000d.html http://www.atomicspeakers.com/7000d.html similar to vfl 500.1 and 700.1 that would be my recommendations.... talk to hornets nest, tell him i recommended you... www.dbdrag.ca Representin' Canada In DB DRAG
slim8605 Posted June 1, 2007 Author Report Posted June 1, 2007 Im looking for whatever is cheapest so probably used. How much are the others usually? 1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock
slim8605 Posted June 1, 2007 Author Report Posted June 1, 2007 thanks again. 1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock
mikeneufeld Posted June 1, 2007 Report Posted June 1, 2007 they vary alot but remeber you need a good electrical system to make these amps happy... i'll find out a price for you... on a few options.. www.dbdrag.ca Representin' Canada In DB DRAG
slim8605 Posted June 1, 2007 Author Report Posted June 1, 2007 yea i figured that. I got a 200amp alt and I'm workin on gettin a pair of kinetik 2400s. 1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock
