right now im pushing about 1100rms total (kicker 750.1 & 350.4). 4 gauge from the battery to a distribution block, 4 gauge to the mono amp and 8 gauge to the 4-channel amp. i got a stock alt (70/80amp) and a stock Duralast battery :P, i get voltage drops and dimming.
what size of wire should i use for the big 3? oh btw i dont think will go over 2000rms for a long time so yeah. any suggestions? thanks alot people.
iDA-X200/Clarion EQS746
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Alpine & Polk Speakers
Stock electrical
right now im pushing about 1100rms total (kicker 750.1 & 350.4). 4 gauge from the battery to a distribution block, 4 gauge to the mono amp and 8 gauge to the 4-channel amp. i got a stock alt (70/80amp) and a stock Duralast battery :P , i get voltage drops and dimming.
Run 0 ga on the big 3 and replace the 4ga from batt to distribution block with 0ga and that should help out some
0 or 01 gauge bro. Knukonceptz sells some cheap but quality wires.
what do you think? will it be a night a day difference if i replaced my 4 gauge hot wire with a 0 gauge?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
http://www.streetwires.com/products/default.aspx?grp=20
Use the two icons for interactive Wire Guide
This will help out, larger wire is always better but in your case it will not make a noticable difference running 1100rms watts
yeah thanks. i think ima just go for knukoncept KLM 4 gauge wire for now. in the future i might just upgrade to a 1000 watt amp.
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
deffinatly use 0 or bigger. remember the bigger the wire the less resistance you have just make sure your ground is 0 as well and its a good clean ground
-Car: 2006 Ford expedition King Ranch
-Subs: 2 FI BTLs 18 fully loaded
-amps: 2 sundown SAZ 3000D
-Alternator: DC Power 260 amps
-Batterys: 2 optima yellowtops
-A whole shit load of 0 guage knu hyper flex and raptor cable
-Rockford Fosegate 3sixty
I'd say run the 0 gauge and run 0 to the amps as well then you could upgrade and not worry about it and for the time being your amps will be well feed.
1994 Dodge Ram 2500 Cummins Diesel Regular Cab
anyone know if MTX mono amps are any good? im looking at a MTX 1000XD. it does 1000rms @ 2ohms, does it really give it out 1000 real clean rms?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
  • Who's Online   0 Members, 0 Anonymous, 866 Guests (See full list)
