AlpineKid Posted January 29, 2010 Report Posted January 29, 2010 Hey I have an alpine type r 12" in a 1.7 ft3 box with a 12" slot, speakers are all alpine type s, headunit cda-9884 and i have the alpine power pack with the gain on "high" so it puts out 45w x4 @4ohms to the speakers according to alpine, when i try to setup the m500 amp for my sub, i have the low pass on 80 Hz gain on .5 volts and the bass boost on 6db, I have searched all over online forums and this site and it states I should not need any bass boost and my gain about half way (the knob) with 0db bass boost my sub doesnt even move even with the gain knob all the way up, which I know is not good/ right. Any help is appreciated I have almost given up on it but the closest audio store is best buy and they are 30min out plus they suck. I got the speakers first, and the headunit, then sub... worked fine.... got the power pack for x-mas and now the speakers sound much better but the sub is :censored: /////ALPINE
alan412 Posted January 29, 2010 Report Posted January 29, 2010 If you are referring to the Alpine MRP-M500 then you shouldn't be disapppointed. I used to own this amp and i can tell you its a little power house! Read the gain setting tutorial on the site and apply what you learn to your setup. Also i highly doubt that your headunit is putting out 45 watts to 4 channels. It's probably more around 18 watts. (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h
Lowroll Posted January 29, 2010 Report Posted January 29, 2010 Yeah you are definately not getting 45x4. my 400/4 amp only puts out 38 watts @ 4 ohms so...thats that. You should definately set your gains with a DMM to prevent clipping. are type R's dual 4? Current System: Pioneer 6900 HU Front Stage: (for now) Soundstream tarantula 5.25 in the doors Soundstream tarantula 4x6 in the dash Kenwood 400.4 for mids & highs Bass: 4 Soundstream RW-12's 2 Power Acoustik Stax 4000/1D's single chamber box, 2.65 cubes. Currently under the knife being bagged Rebuilding err'thang
alan412 Posted January 29, 2010 Report Posted January 29, 2010 Yeah you are definately not getting 45x4. my 400/4 amp only puts out 38 watts @ 4 ohms so...thats that.You should definately set your gains with a DMM to prevent clipping. are type R's dual 4? ^^^good question. a dual 4 would be ideal. that way you could wire it to 2ohm and get 500wrms out of your amp. (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h
Lowroll Posted January 29, 2010 Report Posted January 29, 2010 ^^^good question. a dual 4 would be ideal. that way you could wire it to 2ohm and get 500wrms out of your amp. Is the amp only 2 ohm stable? I just out a m300 in my moms car & I think it was only stable down to 2 but I cant remember to be honest. Current System: Pioneer 6900 HU Front Stage: (for now) Soundstream tarantula 5.25 in the doors Soundstream tarantula 4x6 in the dash Kenwood 400.4 for mids & highs Bass: 4 Soundstream RW-12's 2 Power Acoustik Stax 4000/1D's single chamber box, 2.65 cubes. Currently under the knife being bagged Rebuilding err'thang
alan412 Posted January 29, 2010 Report Posted January 29, 2010 Is the amp only 2 ohm stable?I just out a m300 in my moms car & I think it was only stable down to 2 but I cant remember to be honest. the amp is 2 and 4 ohm stable. it puts out 500wrms @ 2 ohm 300 wrms @ 4 ohm this is ofcourse is the amp is the alpine mrp-m500. he didnt really specify in the title (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h
AlpineKid Posted January 29, 2010 Author Report Posted January 29, 2010 http://www.crutchfield.com/S-uSrAB5nTOy5/p...Power-Pack.html Thats how I'm getting 45w x4 for my speakers, and My sub it wired to 2 ohms but I still don't know how to set it up because following alpines amp manual the type r barely moves if at all... until I crank up the bass boost /////ALPINE
Lowroll Posted January 29, 2010 Report Posted January 29, 2010 You realize thats 45 watts/4 channels right? My pioneer deck does 50x4 by itself which comes out to 18 watts per speaker. As for your sub just crank it up, if it starts to smell bad turn it down. lol Current System: Pioneer 6900 HU Front Stage: (for now) Soundstream tarantula 5.25 in the doors Soundstream tarantula 4x6 in the dash Kenwood 400.4 for mids & highs Bass: 4 Soundstream RW-12's 2 Power Acoustik Stax 4000/1D's single chamber box, 2.65 cubes. Currently under the knife being bagged Rebuilding err'thang
alan412 Posted January 29, 2010 Report Posted January 29, 2010 youre only running 500 watts not 5000 watts. you cant expect it to tear your car apart. (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h
Ray Posted January 29, 2010 Report Posted January 29, 2010 he is right about 45x4 its a small 4ch amp guys. does 45x4 rms 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
