07 Avalnche 2 18 FI Sundown 3500d Zapco 1000.4 Reference
i guess concrete works great for a brace too haha but god damn that is alot of unnecessary weight
R.I.P!
(Nov-29-2009)
92 explorer
current build
just 240 pounds ive seen people put 1000 lbs of battery ?????
just kidding i just read your build good job i dont know i had a friend that used to do really well way back in the day early90's and said it turned some good #'s
i am getting concerned about how my center braces wil effect air flow tho
what do you guys think should i 86 em and brace otherwise if so some suggestions please??????
build is looking good so far
ha over 1000 pounds of batts but yeah the back brace will work great to help the rear
as for your center braces (the 2x4s) they shouldnt really effect the air flow but one thing i would look into doing is adding some 45s or some how making shit rounder to help smoothen out the air flow
edit i had 4 15s in a wall and a 6 layer baffle that was huge
your box is braced to shit and not as big i'd imagen 3 baffles would be enough for you
R.I.P!
(Nov-29-2009)
92 explorer
current build
