aajay602 Posted February 6, 2010 Report Posted February 6, 2010 I JUST BOUGHT ME A TPI 440 Held Digital Oscilloscope. I NEED TO KNOW ON THE RCA JACKS, WHICH LEADS GO ON WHAT WHEN IM ADJUSTING TO SEE WHERE THE CLIPPING STARTS. THX :hairtrick:
Neo_frog Posted February 6, 2010 Report Posted February 6, 2010 NO NEED TO SCREAM FIRST OFF. Secondly, the red lead goes to the center of the RCA (or shielded wire), and the black goes to the shell (or exposed wire). If I'm not mistaken though, it doesn't really matter with AC voltage. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
bobonit Posted February 6, 2010 Report Posted February 6, 2010 you should have a signal probe and a ground clip. Connect the ground clip to chassis ground or the outside ring of the rca if you can, and use the signal probe on the center pin of the RCA. 97 Maxima SE Bunch of shit going in, check out the build Build Log
aajay602 Posted February 6, 2010 Author Report Posted February 6, 2010 On what RCA jack do i put these on? NO NEED TO SCREAM FIRST OFF.Secondly, the red lead goes to the center of the RCA (or shielded wire), and the black goes to the shell (or exposed wire). If I'm not mistaken though, it doesn't really matter with AC voltage.
