Tooshort064 Posted February 8, 2010 Report Posted February 8, 2010 Does anyone know anything about this amp? is it also the famous cheapo brand SPL that you see in pawn shops? just curious about it. specs say. Gorilla Series Class D Digital Monoblock Car Amplifier RMS Power Rating: 4 ohms: 1700 watts x 1 chan. 2 ohms: 2500 watts x 1 chan. 1 ohm: 3200 watts x 1 chan. Max power output: 5500 Watts Regulated MOSFET PMW power supply Bass Remote Details (Wired remote bass level control included) All connections on the front side for easy installation LED power indicators Bass Boost (0-18 dB bass boost at 45 Hz) Phase Shift (180 Degrees) Mono channel operation Bridged Synchronization (Strap amps together to double your power!) Preamp RCA outputs 3-Way system protection circuitry (thermal, overload, and short protection) Brilliant silver texture coat finish Heavy duty die cast aluminum alloy heatsink for extreme heat dissipation Silver-plated RCA level inputs Silver-plated screw terminals Variable low-pass filter (40-200 Hz, 12 dB/octave) Subsonic Filter (12 dB at 20-50 Hz) Frequency response: 15-150 Hz Dimensions: 17"L x 8-1/4"W x 2-1/8"H 1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier. Authorized Internet Dealer 1-year Manufacturer's warranty http://www.sonicelectronix.com/item_17908_...LA5500-1D-.html 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
Tooshort064 Posted February 8, 2010 Author Report Posted February 8, 2010 still no answer. I thought you amp guru's would have chimned in by now 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
r00k Posted February 8, 2010 Report Posted February 8, 2010 Probably doing there homework! Looks like a nice amp but i'm not a guru. Think it has enough fusses? lol
EclipseChris Posted February 8, 2010 Report Posted February 8, 2010 when it comes to the inputs and the specs it looks EXACTLY like http://www.sonicelectronix.com/item_14906_...MF55001-D-.html odd and if you looking to buy http://cgi.ebay.com/POWER-ACOUSTIK-BAMF550...#ht_4338wt_1165 i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
Tooshort064 Posted February 8, 2010 Author Report Posted February 8, 2010 Ok NVM I do not like anything by power acoustik 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
yoli Posted February 12, 2011 Report Posted February 12, 2011 Hello, I have the SPL GRLA 5500/1D, and I can say for the money its a pretty good amp! The amp have a lot of power for his size(its a little smal in size). I have run it in 1 ohm 4 ohm and 0.5 ohm and puts allot of power. I run it on 4 Pioneer 121 SPL on 0.5 ohm and the amp power's them pretty good, before I had only 2 of the pioneer's and the Gorilla pretty much burned the hell out of them at 1 ohm. If you want pictures inside and you have questions you can ask me in facebook or skype. Sorry if my writing is bad but I'm from Bulgarua and my english is pretty bad
dugee81 Posted February 12, 2011 Report Posted February 12, 2011 just for future references, a good spec to look at is the fuse rating. 40a x 5 40 amps * 5 = 200 amps 200 * 14.4 = 2880 2880 * .8 (typical class D efficiency) = 2304 so at a 1ohm load, you could maybe, MAYBE see around 2300 watts. again this is just a guideline to helping decide whether an amp is worth the money. it will NOT put out the "rated" 3200 watts, maybe if you ran it at 18v. then the question is: is the amp stable at 18v? i would say just look into a different amp, with a more accurate fuse-rating-to-specs ratio. edit:and then i fucking realize how this thread is over a year old, and was resurrected. FML! 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
