i have a DC lvl 4 18" i was thinking of making a 4th order but don"t know much about them.
the max space i have in my truck is about 8 to 8.5 cubes is it possible to fit one in that amount of space?
In your guy's experience dose a 4th order normally get louder or lower then a ported box
my current box is 6 cubes tuned to 32 according to the RE calculator but i think its off some
band passes are tricky
rule of thumb for a 15 you need 1.5 cubes sealed and for an 18 roughly 2 cubes sealed
2-1 ratio is musical
3-1 both musical and spl
4-1 way to peaky
and there usually tuned roughly to 60 hz
so for your 18 you'd need roughly an 8 cube box 2 sealed and a 3-1 ratio you'd need 6 cubes ported
then comes the guessing/trial error shit and when you play with port area and what not and play with shrinking the box to dial it in
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
4-1 way to peaky
ok i should be able to do that
where dose 60hz come from i realize its different then a normal box but i want to hit real low because 85% of the music i listen to is slowed
the sealed part of the box tunes your lows depending on how big the box is, and the ported being 60 gives you the highs so you have a spread from say 30-60 hz
and as for removeable port its not really necessary but what i would do is have a removeable top layer so you can access sub and the port from the top
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
ok sounds good
and would making the 2 cubes smaller by adding extra bracing make it hit lower of higher?
Edited by ben29555
