Distrobution Blocks
Just like it says, Do power distribution have to be fused?
I know grond block aren't but the power ones all are, is there any particular reason you'd want smaller fuses on each output?
Is it because you'd put like a 200 amp fuse on 1/0 and you'd want a smaller fuse for eash amp?
Reason I ask is I was looking at this:
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-23
ANd it said:
The KNF-23 has two input ports, which by changing the Kompression Fittings, can accept 4 Gauge or 1/0 Gauge Cable . The two of the three ouputs can be adjusted to accept 4 Gauge or 8 Gauge cables while the last output can be configured for FUSED 1/0 or 4 gauge output .
And I was all "lolwhut?" Aren't all three outputs fused?
I'll be running 3 amps, btw, so this is perfect for me and I really like the kompression connection system.
[HOONIGAN]*
'01 Ford F-250 LWB
JVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4
  • Who's Online   0 Members, 0 Anonymous, 1234 Guests (See full list)
