someone help!!!! Couple of ?????
Well first off..I want to know how does one wire up 6 component speakers... I will have to use 2 amps dedicated to mids/highs..So how do I go about using rca's back to the headunit so I have control over all speakers.....Or do I need to wire some speakers together to only use one amp??????
do you mean 6 sets or just six?
on my system i have 4 sets 8 speakers total.
what im gonna do is......
fr back of head unit front rca will go to left side
of a 4 channel amp. rear rca to the right. now the 2
left side channel will wire to front 2 sets.
the right will wire to the rear 2 sets. each single
set of speakers is wired in parallel at a 2 ohm load.
this will give me the ability to use my fader from
front to rear.
if you use only one amp , double check ur ohm load
capabilities .
sony m60ui
polk mid/hi's
infinity 6000m on tower
fosgate p3d212 x2
fosgate p400-4
fosgate t1000-1bd
im ona boat bitch
My boat build
funny thing is...............slamming fireworks in to the ground with a sledge hammer in mexico is like car audio in california... everyone is doing it but most fail :)
Every time I read a comment you post, or a topic you make... I cannot help to think of how much of a badass you are!!
front to rear.
capabilities .
X2 beat me to it but i would say put the front rca's to the front speakers and the rear rca's to the rear speakers
Greg,
Triple C Auto Niagara Falls NY
Under construction
2002 Chevy Suburban
pioneer 8000NEX
3 Sets of ARC Audio 6000 components in custom front doors
2 Powerbass midrange in center council
4 Super tweets
2 Focal 900.6 6 channels
4 American Bass VFL Comp 15's (currently running 2)
DC 12.0k
DC Power dual alt bracket
2 XS Power D3400's under the hood
3 C&D technologies 110ah in rear
along with multiple runs of 0 AWG OFC
front to rear.
capabilities .
i couldnt of said it better
trailblazer
18" xl
aq2200
147.8db at 4 ohms
yes
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
So If I want to wire them to 1 amp.. I should wire them in sets per channel.... I think I'm gonna buy another set.... there will be a set in the A pillar,kick panels, front doors, and rear doors
yes one amp will work preferably a 4 channel that is
1 ohm stable. 2 sets of 4 ohm speakers in parallel is
2 ohm load.
what ilove2install sed was correct also i was thinkin
my 4 channel amp would have two imputs(duh) it
has 4 . 2 front 2 rear.so makes rcas even easier to
hook up.
sony m60ui
polk mid/hi's
fosgate p3d212 x2
fosgate p400-4
fosgate t1000-1bd
im ona boat bitch
My boat build
  • Who's Online   0 Members, 0 Anonymous, 435 Guests (See full list)
