wanna no if its possible to wire both voice coils to 2 my 1000 watt 2-channel amp.
i have a 2-channel amp thats 1000 watts n a mtx 7500 series thats a dual voice coil.
ya. depending on what ohms your voice coils are you show be able to bridge ur amp to 1 channel and run the sub off it no problem. hell im running 4 single coil subs in 1ohm on a 1 channel amp right now. :hairtrick:
why not bridge it then wire the coils in parallel?
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
Dude that sig is huge your probably going to have to change it
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
just made it, im a friggin newb lol
Its obnoxious. please change it.. or size down the pictures.
84 K5 Blazer
3" body, 2" Suspension
35" Maxxis Bighorn
100amp Alt
Marine deep cycle for the amps (freebie)
KnuKonceptz 1/0
8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz
Audiopipe AP-18001D
RF 5x8's in the kicks
Almani 5.25 comp. in back
Kenwood KAC-645
--IN THE FUTURE--
None.
<!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
haha its all good. id upload them to photobucket and resize em
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
Yes the odds are that you can wire the voice coils together and run the amp bridged.
An amp that is stable at 2 ohm stereo put out the same amount of power at 4 ohm bridged. If the amp is stable at 1 ohm stereo (1 ohmx2) then it can handle a bridged 2 ohm load and should put out the same amount of power as it being wired at 1 ohm stereo mode.
Why do you not wire 1 coil to each channel? Because sometimes music only has information on 1 channel and not the other and it is not good for the woofer to recieve an unequall amount of power at anytime.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
makes sense now. thx bro
  • Who's Online   1 Member, 0 Anonymous, 705 Guests (See full list)
